initializing ram with hex file
I am using Quartus/DSPBuilder 9.0 Matlab/Simulink 7.5 (aka R2010a) Vista Home DE2 Cyclone II kit I am having trouble initializing RAM with Intel hex files. I warnings like the following: Critical Warning: Can't read Memory Initialization File or Hexadecimal (Intel-Format) File simpleTest.hex -- setting all initial values to 0 However, I know the application can access this file, since if I deliberately put some bogus data in the file, I get errors (as expected) such as: Error: Data size does not match the number of bytes at line 4 in Hexadecimal (Intel-Format) File "simpleTest.hex" File: simpleTest.hex Line: 4 If the file was misplaced or innaccessible, I wouldn't get that error. I have tried local files in the same directory as well as absolute and relative paths to files in other directories. Always get the same warning. I have also tried moving the file to various places (in the same folder as my mdl, subfolders, far away, etc). No luck. Any suggestions? Thanks.6 Replies
I think a bad checksum may cause that, but not really sure. Can you try creating a .mif instead of a .hex to see if that acts the same? It seems to be the content as you said --
I actually don't think it's the content of the file at all. What I was trying to say about bogus data was that if I *deliberately* put in a bad checksum or extra garbage characters, I get an error indicating the data is bad, which indicates that Quartus/DSPBuilder can access the file.
However, when I use a hex file that I know has correct checksums, I get the critical warning about being unable to read the file. So I suspect it's some kind of configuration error or such. Thanks. - Altera_Forum
hi i have an error :
Error: Generated checksum value does not match the value specified at line 1 in Hexadecimal (Intel-Format) File "Look1.hex" http://www.alteraforum.com/forum/../proweb/misc/progress.gif can you help me i change the .hex file for an on-chip memory with result of code matlab i wanted to change the contents of memory with data wich i generated with matalab - Altera_Forum
Hi, Sam. I have not used matlab and can only suggest using Quartus do generate the file.
I have my own program to generate my .hex. I have not done it recently so I'm a bit rusty. My suggestion is to copy the text that you input to matlab and paste it in the source for Quartus to gen the .hex. Good luck. - Altera_Forum
thks i resoklve the problem i have an error in my own code matlab i fixe it and it is work thanks so much
hi i resolve this problem by changing my code in mtalab the cheksum in the end is wrong then i correct it with my own code because in my project i put data in ram wich are genereted with matlab chek ur data
