Zarquin's avatar
Zarquin
3 years ago
Incorrect values from TX-Fifo in Avalon PCIe Example
The endpoint TX-Fifo from the Avalon-ST Chaining DMA PCIe example outputs an incorrect tx_st_eop signal. During a signal tap II analysis of the Chaining DMA example, I noticed that the tx_st_eop r...
  • FvM's avatar
    3 years ago
    still think that it's a misinterpretation of tx_st interface data. st_data and st_sop and st_eop are only valid while st_valid is active. I know that in typical Avalon ST examples, sop and eop are reset together with valid, but as far as I understand, it's not required by the specification. See this explanation of valid signal:
    Asserted by the source to qualify all other source to sink signals. On ready cycles where valid is asserted, the data bus and other source to sink signals are sampled by the sink, and on other cycles are ignored.
    Frank
