14 years agoimplement ram with logic blocks
Hi all! I am designing an Avalon-MM interface with a page system: a page register is used as address of a memory and a data register is used to read/write the memory. The memory I instanci...
14 years ago --- Quote Start --- up: so does use_eab => "OFF" works for altsyncrams? --- Quote End --- I did use it once for a dcfifo, but I checked the help (QII 9.1sp2 and QII 11.1sp1) for altsyncram and there the parameter seems to be "IMPLEMENT_IN_LES" which you want to set to "ON". Why don't you try this?
