14 years agoimplement ram with logic blocks
Hi all! I am designing an Avalon-MM interface with a page system: a page register is used as address of a memory and a data register is used to read/write the memory. The memory I instanci...
14 years agoIndeed, I should have copied a bit more from my code:
use_eab => "OFF", will force usage of LE-registers to build the memory block
