14 years agoimplement ram with logic blocks
Hi all! I am designing an Avalon-MM interface with a page system: a page register is used as address of a memory and a data register is used to read/write the memory. The memory I instanci...
14 years agoAgreed!!
We are desperatly in need of memory and can't afford to waste M9K like this :( MLAB would be better than M9K, but my question was: is it even possible to force implementation with logic elements? I think there is an option like this for FIFOs:
Parameter use_eab
Type String
Required No
Description Specifies whether or not the FIFO megafunction is
constructed using the RAM blocks. The values are ON or
OFF.
Setting this parameter value to OFF yields the FIFO
megafunction implemented in logic elements regardless of
the type of the TriMatrix memory block type assigned to the
ram_block_type parameter.
Thx Julien
