Implement a Remote System Upgrade in FPGA fabric
Yes, you may use MAX V for that. I don't see any issue in your use case unless you need to use some IP which the max10 has such as NIOS II.
Meanwhile for this:
3) Seen also in one of the documents that "Altera recommends storing only 1 application image at 1 sector boundary" as I try to implement above. Is this the case ?
or is it better to just select 'Auto' when converting from .sof -> .pof and let the Quartus tool automatically set the start address for each Page ?
I believe i have already answered this in your another thread, which you filed multiple thread every day. Let me explain here again, it would be better if you could select auto for every page. You may also set the start address youself but make sure it wont write on the address of the other SOF file and also on the address where the option bits is located in.
Hi @YuanLi_S_Intel ,
Thanks for your following reply & sorry for raising other tickets - reason why I did that is because seen no solid complete answers to the previous ones. Will try to keep my main communication to this ticket from now, onwards unless something else new comes up unrelated to this one.
Please see my latest comments :
1) So the data can be any data (doesn't need to be special passive). Does the PFL when it receives the parallel data/address sort this scheme out before the flash is programmed and can then passive configure successfully the Cyclone V FPGA ?
Sorry, to clarify also one of my previous statements. Wrt my other following ticket query, our remote host I2C has just links to our FPGA Cyclone V (and not direct links to the CPLD (MAX V)) before the new application image data gets forwarded to the CPLD (MAX V) with the use of the PFL IP core to program the flash :
Can we just implement our own logic circuitry within Cyclone V FPGA (without the use of the Remote Update IP) to receive remotely the new application image data (just chunk bare data) from our external host via I2C serially (and also convert it from Serial-2-Parallel within the Cyclone V FPGA) and then be able to load/update/store it to the PFL (PFL is within CPLD MAX V) new sector location as parallel data ready to program the flash?
2) Since we instantiate the PFL IP core within CPLD MAX V for FPP or PS configuration we can use the features in the PFL IP core to perform remote system upgrade. My understanding within the CPLD we will need to enable the extra 'pfl_nreconfigure’ port of the PFL & generate the fpga_pgn[2:0] via user logic to implement the state machine diagram as shown in Fig.16 pg20 of the Parallel Flash Loader Intel FPGA IP User Guide
Isn't this the case?
3) So, are we able to still achieve this data transfer via I2C to Cyclone V FPGA through to MAX V CPLD -> PFL_ip with the above suggested implementation use case ? Please re-confirm
- Knug5 years ago
Contributor
Please resend me your answers here because I do not see the reply you already sent me listed now.
Read it this morning and went back to read it again but it is not there!
Kevin
- Knug5 years ago
Contributor
Its ok now. Sorry. Seen your reply once I sent you the last message.
Don't know why I could not see your latest reply a while ago.
What is the best way to view replies ?
Kevin
