16 years agoIFFT odd behavior
I'm at the tail end of a design that uses 2D FFTs, does phase correlation calculation in frequency domain then does 2D Inverse FFT to get spatial shift between two images. I'm finding that the ...
16 years agothepancake
I did consider some type of dc offset going on. However, I don't see this zero position spike in the Verilog sim which is full of truncations. Actually, the Matlab core model sim is designed to truncate values exactly how/where I truncated the Verilog values so that I have exact match between the two. It just looks like a difference between the Verilog simulation model (.vo) and the Matlab core model. Will crawl thru the two sims again to look for any difference. I would just ignore it but a spike at the (0,0) point is valid for no shift between the two images which is a possibility. Thanks for your input.
