I2C Slave to Avalon MM Master bridge IP - Consecutive Write problem from odd addresses
We have a Qsys system with an I2C Slave to Avalon MM Master bridge IP connected as master to an On-Chip RAM.
When writing consecutive bytes to to the I2C Slave of the "I2C Slave to Avalon MM Master bridge IP" with a start address other than 32bit boundary(like 0x01, 0x02 or 0x03) the transaction is split up on the Avl MM side and two of the data bytes are used as address bytes in the next Avl MM write.
Writing with start address of 0x00 or 0x04 works fine.
Example:
Starting from i2c address 0x5, writing 8 bytes. Data in first byte is 1 and the value is incremented for each write operation. Expected output would be:
Adr |
0x5 |
0x6 |
0x7 |
0x8 |
0x9 |
0xA |
0xB |
0xC |
Data |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
But reading from the same address gives:
Adr |
0x5 |
0x6 |
0x7 |
0x8 |
0x9 |
0xA |
0xB |
0xC |
Data |
1 |
2 |
3 |
0 |
0 |
0 |
0 |
0 |
It seems that the data for the fourth and fifth write operation somehow ends up in the i2c address. Reading 16 bytes from i2c address 0x400 gives:
Adr |
0x400 |
0x401 |
0x402 |
0x403 |
0x404 |
0x405 |
0x406 |
0x407 |
0x408 |
0x409 |
0x40A |
0x40B |
0x40C |
0x40D |
0x40E |
0x40F |
Data |
0 |
0 |
0 |
0 |
0 |
6 |
7 |
8 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
Doing the same write operation as above, but with a starting data value of 2.
Reading from address 0x5:
Adr |
0x5 |
0x6 |
0x7 |
0x8 |
0x9 |
0xA |
0xB |
0xC |
Data |
2 |
3 |
4 |
0 |
0 |
0 |
0 |
0 |
And this time the rest of the data ends up in 0x506:
Adr |
0x500 |
0x501 |
0x502 |
0x503 |
0x504 |
0x505 |
0x506 |
0x507 |
0x508 |
0x509 |
0x50A |
0x50B |
0x50C |
0x50D |
0x50E |
0x50F |
Data |
0 |
0 |
0 |
0 |
0 |
0 |
7 |
8 |
9 |
0 |
0 |
0 |
0 |
0 |
0 |
0 |
This is how the signals look on the external I2C Slave SCL and SDA pins for a consecutive write starting at address 0x05:
Any ideas what may be wrong?
Is it a problem with the IP?
1 Reply
- SyafieqS
Hi Nikolay,
Any update on the issue?
