14 years agoI2C core issue
Hello. I want to use Wishbone I2C core from OpenCores in my Nios project. Trying to send a byte, i write 0xA2 byte to TxR and set STA and WR bits, the TIP flag asserts high and then never negates ...
14 years agoskaneta,
clock rate iss not a generic; it's programmed into a configuration register -- you configure the division factor. CosworthRS, as other have pointed out, you have the SDA and SCL signals wrong. First, you should take the sda_i, sda_o and sda_oen signals to the FPGA top level. Common practice is not to have internal tri-state signals in FPGA designs. Secondly, the correct way to handle it is: sda_i <= SDA; SDA <= '0' when sda_o = '0' and sda_oen = '0' else 'Z'; Rinse and repeat for SCL. This will get Quartus to infer an open drain configuration for the SDA and SCL pins.
