Yes, your understanding is correctly. If you would like to CMU PLL, then you can only use CH0 and CH2. If you plan to use 3 of the duplex XCVR channels at the same data rate, then you can explore using external fPLL to drive all the 3 XCVR channels. Note that when you use the CH1 as duplex XCVR, then you would not have a CMU PLL because it is located in the RX channel.
You may refer to the following design example for further details:
Note that in your selected part, there is only one 3-CH XCVR banks. If you would like to implement 2 different data rates, I am not sure if there are sufficient fPLL resources on the same side for your selected part, You might need to create test design to check on this.
Chee Pin
