CheepinC_altera
7 years agoHi,
Regarding your inquiries on setting the serial loopback in Custom PHY, for your information, you will need to perform register writing to enable the serial loopback. You may refer to the XCVR PHY IP user guide -> "PMA Control and Status Registers" -> "phy_serial_loopback" register for further details.
By the way, to ease your debugging, I would recommend you to create a new simple one channel test design with Custom PHY in RTL to avoid any dependency on the XCVR toolkit and design example.
You may try to refer to the following AV Custom PHY design to enable serial loopback:
Chee Pin
