WQIUS
7 years agoHi:
Now, I have a new question to ask you.
In the file”AN585 page:3:PHY LOOPBACK ”, it mentioned the message to enable the loopback function in GXB:
To set the sd_loopback bit , you need to do a configuration write to the PCS control register.
Also, I learn that the custom PHY can set loopback function, if there is a detailed steps to follow to set the loopback function?
And, I download the design examples “transceiver_toolkit_13_0sp1_qar”,in which there is a folder “cv_GX_1ch_40b_3125mbps”,I change it to 1000Mbps, and change the device, but when I run the transceiver toolkit, it always has some error, then, I delete the PLL in the top.v file ,and there is no error . As I do not set the loopback, I can only see the TX .
So, what is this problem? And ,How can I set if I want to check the TX and the RX channel with loopback?
(cyclone V: 5CGXFC3B7F23C8N)
Thank you.
王秋实 中广核研究院北京分院 技术支持部
联系电话:010-82193500-279
手机 :18810644922
邮箱 :wangqiushi@cgnpc.com.cn
