Yes, your understanding is correctly. If you would like to CMU PLL, then you can only use CH0 and CH2. If you plan to use 3 of the duplex XCVR channels at the same data rate, then you can explore using external fPLL to drive all the 3 XCVR channels. Note that when you use the CH1 as duplex XCVR, then you would not have a CMU PLL because it is located in the RX channel.
You may refer to the following design example for further details:
Note that in your selected part, there is only one 3-CH XCVR banks. If you would like to implement 2 different data rates, I am not sure if there are sufficient fPLL resources on the same side for your selected part, You might need to create test design to check on this.
Chee Pin
- WQIUS7 years ago
Hi: sorry to disturb you. There is a question for you to ask. Regarding the GXB channel test, it uses a differential crystal. How can I test if the differential crystal is working properly? In addition, If I use the transceiver toolkit to test GXB channel send and receive, do I need to add “JTAG to Avalon Master Bridge” in the program to find this channel in the transceiver toolkit? - WQIUS6 years ago
Hi: Sorry to disturb you,there is still a question ask, I use the cyclone V(5CGXFC3B7F23C8N)chip, about the crystal size of the GXB required, how should I choose?can 125M be?LVDS or LVPECL? Are there any special requirements? —————————————————————— 王秋实 中广核研究院北京分院 技术支持部 联系电话:010-82193500-279 手机 :18810644922 邮箱 :wangqiushi@cgnpc.com.cn
