9 years agoHybrid Memory Cube Controller IP
Hello, I synthesized the example design for the HMCC with no errors. However, I cannot generate the programming files because my license does not support this IP ( ID# 115003 on Quartus 15.1 ...
9 years agoThe HMCC requires an additional IP license. You can run it in OpenCore Plus mode, but you'll need a license to generate standalone programming files.
