FPGA1
5 years agohps ddr3
hi
In HPS, I connect an Avalon-mm-bridge host to f2h-Axi-slave, and export the slave of Avalon-mm bridge from the machine. Can I read and write DDR3 on the HPS side directly?
EBERLAZARE_I_Intel
5 years agoHi,
It is recommended that you do all interconnect and bring it inside Platform Designer than exporting it out. If you are trying to access the DDR3 of the HPS , you will need a EMIF IP for the HPS and set the settings a per spec of your DDR connect it to the HPS.
