How to use CXL IP Design Example on DK-DEV-AGI027RBES
- 2 years ago
Hi there,
Firstly, we should make sure the device enter into the user mode.
Secondly, could you make sure all the switch like the default setting in the user guide.
If all this you make sure, I will upload a pof file for you and you can try.
Of course, it is not ruled out that the problem may be caused by the system.
WZ
Any update~
- hxhaa2 years ago
Thanks for your help, I succeed to find the 0ddb in my system and run the mlc.
Best regards
- hxhaa2 years ago
Hi ,
I notice the cxl example design with 4 slices can't be generated with specific board. I selected none in example design development board, and assigned pin. I refer the .qsf in example in install package download from Intel Agilex® 7 FPGA I-Series Development Kit, and assign pin for dimm channel. But it can't work.
Considered about no classic example to use, I guess the use of dimm is different from comp. I notice that the example memory design in install package for dimm is x4 x72, and for comp is x8 x72.
Are there any qsf or design to refer for using more than 2 slice. I need to use all ddr channels on the board.
