hxhaa
2 years agoHow to use CXL IP Design Example on DK-DEV-AGI027RBES
I generate design example in quartus 23.3, choosed type2, AGI027RBES and other config default. The project compiled with timing warnning in Timing Analysis, but the sof file is generated in output...
- 2 years ago
Hi there,
Firstly, we should make sure the device enter into the user mode.
Secondly, could you make sure all the switch like the default setting in the user guide.
If all this you make sure, I will upload a pof file for you and you can try.
Of course, it is not ruled out that the problem may be caused by the system.
WZ
WZ2
2 years agoHi there,
Yes, according to your description, your device's configuration success. Before check the system bug, you check the state of link to make sure the link training succussed. I also will upload a pof file which I verified.
About documents, 723393 also a useful document, however it seems belong to confidential info, you can ask it to your FAE or sales.
WZ
- WZ22 years ago
The pof
