How to use CXL IP Design Example on DK-DEV-AGI027RBES
- 2 years ago
Hi there,
Firstly, we should make sure the device enter into the user mode.
Secondly, could you make sure all the switch like the default setting in the user guide.
If all this you make sure, I will upload a pof file for you and you can try.
Of course, it is not ruled out that the problem may be caused by the system.
WZ
Hi there,
I see, you may refer the wrong user guide. RBES is the new board, sw4 is a JTAG setting for the old board, and you can refer the default switch on page 13 on https://www.intel.com/content/www/us/en/docs/programmable/683288/current/overview.html
Pay attention, on sw8.
And if you still cannot find the device, please go to programmer-> tools-> configuration debugger-> device info and read out the boot stage of device to make sure the device enter into user mode.
WZ
- hxhaa2 years ago
Hi WZ,
I set sw8 off/off/off/off and sw4 off/off/on/off and enter into user mode. Now the D11 of fpga turns on. Is it means the fpga configuration succussed?
But the system still can't grep 0ddb device, maybe you are right it is caused by the system. I will try it at other system if the fpga work.
Actually, I refer the 763513/763328 document published at 2023.10.11 for quartus 23.3, are there other documents to use? I want to know more about cxl ip and how to use its example design.
hxh
