How to use CXL IP Design Example on DK-DEV-AGI027RBES
- 2 years ago
Hi there,
Firstly, we should make sure the device enter into the user mode.
Secondly, could you make sure all the switch like the default setting in the user guide.
If all this you make sure, I will upload a pof file for you and you can try.
Of course, it is not ruled out that the problem may be caused by the system.
WZ
Hi there,
WZ
Thanks for your reply.
There are some questions need your help.
What is user mode? How to enter into?
The default switch setting for DK-DEV-AGI027RBES switch4 is on/off/off/off in user guide, but it makes the JTAG unknown. I try to program flash at off/off/off/off, and use at on/off/off/off, it can't work. How to set it?
I know it may be caused by the system, but now the D11 LED is off. It means I have some wrong operation for FPGA.
Maybe a pof is needed if these questions are solved but it also can't work.
hxhaa
