19 years agoHow to implement PCI Express into my project.
Hello, I have created the PCIe project according to example mentioned in PCI Express Compiler User Guide(2nd chapter). After compilation, pin assignment and programming the StratixIIGX my PC ca...
18 years agoHi friend,
It seems that we are using different examples. Im using the example created by megacore wizard, like it was described in the PCIE Compiler User Guide. The second thing is that im using Quartus v6.0 with PCIE compiler 2.1.0. In that example you can use access either DMA or target memory writing or reading from altsyncram RAM memory. To verify the data im using the application program supplied with the development kit (Application GUI). I can attach my project shortly if necessary. Igor.
