19 years agoHow to implement PCI Express into my project.
Hello, I have created the PCIe project according to example mentioned in PCI Express Compiler User Guide(2nd chapter). After compilation, pin assignment and programming the StratixIIGX my PC ca...
18 years agoHi Igga,
Thanks for your update. --- Quote Start --- In the pex_example_top you can find altpcierd_master entity which is responsible for DMA. --- Quote End --- - <variation name>_example_top.v for Simple DMA doesn't appear to have such entity. Nevertheless, I suppose under - --- Quote Start --- datain and dataout signals --- Quote End --- - you were referring to rx_inN and tx_outN signals - correct me if I'm wrong. In addition, what tools do you use to verify sent and received data? I believe the entity you referring to (altpcierd_master) is actually located in altpcierd_example_app.v Kind regards, Maxim.
