19 years agoHow to implement PCI Express into my project.
Hello, I have created the PCIe project according to example mentioned in PCI Express Compiler User Guide(2nd chapter). After compilation, pin assignment and programming the StratixIIGX my PC ca...
18 years agoHi guys,
We were also trying to modify Chaining DMA Example design in a way to incorporate our own custom Endpoint design into it. Ultimately, the design was supposed to stream data to and from PC through PCIe. Although the project can be compiled and the board is detected by PC correctly, so far we were unable to feed data from FPGA to PC and verify it's reception on PC's side. In this relation, if you could share any bits of information/design files/projects/tips regarding your positive experiments with PCI Express Compiler it would be much appreciated. Thanks in advance, Maxim.
