19 years agoHow to implement PCI Express into my project.
Hello, I have created the PCIe project according to example mentioned in PCI Express Compiler User Guide(2nd chapter). After compilation, pin assignment and programming the StratixIIGX my PC ca...
18 years agoHi guys,
I could make the board to be recognizes by PC. SignalTap and test_out signals can help to identify the problem. Another thing is that there are some timing violations in the project. If i start sending/reading the data, after a few cycles the board fails and then cannot be recognized by PC till the next reset. It is important to enter all the parameters in megacore manager properly. Does anyone of you managed to make the board working stable while reading/writing the data? Best wishes for a pleasant day! Igor.
