14 years agoHow to implement a C routine to VHDL?
Hi, I am trying to rewrite C routine for ethernet (sending of a packet) to VHDL. And I would like to know, how can I write command for setting up some configuration in ethernet driver registry. ...
14 years ago --- Quote Start --- I suppose that there is a requirement for setup and holt time only in "sd" data case --- Quote End --- Your initial example is also violating T1. There are some more points to consider, I won't elaborate a single detail now. If you want to squeeze DM9000 timing, you possibly should provide a faster clock for the state machine. Or implement double data rate output registers for some signals to achieve a finer timing control. P.S.: I just realized the difference between DM9000 (which I previously used) and DM9000A. The timing has been considerably improved.
