14 years agoHow to implement a C routine to VHDL?
Hi, I am trying to rewrite C routine for ethernet (sending of a packet) to VHDL. And I would like to know, how can I write command for setting up some configuration in ethernet driver registry. ...
14 years agoFVM:
In the attachment, there is a timing of DM9000A IOW, I suppose that there is a requirement for setup and holt time only in "sd" data case (10ns for setup and 3ns for hold)? And as you said - second state machine, do you thing something like this (example)? I think If I have a maximum delay 10ns, so one clk period with 50MHz frequency (T = 20ns) should be enough, right?
IF (clk'EVENT AND clk = '1') THEN
CASE state IS
WHEN s0=>
IF input = '1' THEN
state <= s1;
ELSE
state <= s0;
END IF;
WHEN s1=>
IF input = '1' THEN
state <= s2;
ELSE
state <= s1;
END IF;
WHEN s2=>
IF input = '1' THEN
state <= s0;
ELSE
state <= s2;
END IF;
END CASE;
END IF;
END PROCESS;
PROCESS (state)
BEGIN
CASE state IS
WHEN s0 =>
-- delay 10ns
WHEN s1 =>
-- delay 20ns
WHEN s2 =>
-- delay 5us
END CASE;
END PROCESS;
* sorry for small image in the attachment, I haven't got enough of posts for url.
