14 years agoHow to implement a C routine to VHDL?
Hi, I am trying to rewrite C routine for ethernet (sending of a packet) to VHDL. And I would like to know, how can I write command for setting up some configuration in ethernet driver registry. ...
14 years agoSynthesizable VHDL has no concept of delays or sequential programming like in C.
Only things that can be implemented with sequential (flip-flops, RAM) and combinatory logic. Therefore, you need to implement a state machine and counters to implement the delay. Something like this: process (clk) -- 100 MHz clock, 10 ns period if rising_edge(clk) then if state = state:1 then iow <= '0'; cs <= '0'; cmd <= '0'; state <= state_2; elsif state = state_2 then sd <= x"02", delay_counter <= 2000; -- 2000 * 10 ns = 20 µs state <= state_3; elsif state = state3 then if counter = 0 then state <= state_4; else counter <= counter - 1; elsif state = state_4 then cmd <= '1'; state <= state_5; elsif state = state_5 then sd <= x"FF; ... end if; end process
