14 years agoHow to get the FIFO informations
hi all , recently i modify the reference design "a2gx125_qsys_pcie_gen1x4_11_0_1"(using a dual clock onchip_fifo_memory replace the original onchip_memory,BTW,thanks to the author of this reference d...
14 years agoI suggest you start reading the Altera PCIe user guide: http://www.altera.com/literature/ug/ug_pci_express.pdf
It explains the interfaces available from the PCIe cores. You will have to write a custom component to handle the Avalon-ST or Avalon-MM interface without a Nios. Using hard core on an ArriaII, you have to use a 64-bit Streaming interface, which means you have to pull apart the TLPs yourself. I recommend getting the mindshare PCIe system architecture book, that explains how TLPs should be generated and controlled. http://www.mindshare.com/learn/?section=11e3067e0ba2
