17 years agoHow to enable the reflck divider
I'm using the ALT2GXB block in XAUI mode and I want to the enable the refclk divider (using an Arria GX). The megawizard doesn't allow this. The other question is that if I want drive the GXB through the use of a clock other then refclk, how do this through the constraints? Regards MTNo RepliesBe the first to reply
