14 years agoHow to display the terminal through VIP
Hi
My environment is DE0 board and uClinux-20110630. I can boot the uClinux kernel and operate it. I want the shell terminal displays on screen through DE0 VGA instead of screen on my host device Althought I study a lot of information such as adding hardware of VGA controller and frame buffer into SOPC, I don't know how to connect with that. Therefore I really need the design flow or studied direction to solve the problem Could you give me some suggestion Thank you very much3 Replies
Excuse me. My English is very poor.
If you don't understand me what I said. Please tell me. Thank you very much I really need your reply - Altera_Forum
You'll need to find info on 'dumb' frame buffer displays for Linux. There might be some stuff there for 'console' as well as X displays.
Otherwise you need to find a simple bitmap font and do it yourself! Not that difficult provided you don't need to support any/many escape sequences. If the 'console' is likely to be hidden, can be worth saving the raw character stream instead of the bitmap - much faster. - Altera_Forum
--- Quote Start --- You'll need to find info on 'dumb' frame buffer displays for Linux. There might be some stuff there for 'console' as well as X displays. Otherwise you need to find a simple bitmap font and do it yourself! Not that difficult provided you don't need to support any/many escape sequences. If the 'console' is likely to be hidden, can be worth saving the raw character stream instead of the bitmap - much faster. --- Quote End --- I would study the key word "dumb". Thank you for your reply.
