PStep10's avatar
PStep10
6 years ago
How to disable watchdog timer on MAX10 Dual Configuration IP?
I am using Dual Boot feature of MAX10, where CFM0 contains factory image (failsafe) and CFM1 contains operational image. I have enabled reconfiguration watchdog timer in Quartus 19., but when I set relevant bit in the control register of the Dual Configuration IP to reset the watchdog, MAX10 re-configures to the previous image. How to stop the watchdog timer with Dual Configuration IP?
  • ShafiqY_Intel's avatar
    ShafiqY_Intel
    Hi PStep10,
    There is no option/setting in Dual configuration IP to disable the watchdog timer.
    There only way to disable it through Convert Programming File setting (in Quartus): 
    Matt
    • PStep10's avatar
      PStep10
      Hi Matt,
      I am aware, that watchdog timer can only be enabled from File Convert settings. I was referring to reset watchdog register. Once the watchdog has been enabled it will count down and then trigger reconfiguration.
      I am looking for an option to stop/reset watchdog through the registers. There is a bit 1 in register offset 0x00 (ug_m10_config.pdf) named "reset watchdog timer", but when I set this register MAX10 does reconfigure to a different CFM. I think this is not the correct behavior.
      What is the method of stopping watchdog timer without triggering reconfiguration?
      Kind regards,
      Piotr
        ShafiqY_Intel
        Hi Piotr,
        The IP register can only reset the watchdog timer. If you want to disable it, you can disable it in File Convert Programming File tools.
        May I know how you reset the watchdog using the register? If possible, send me the screenshot of your command or write it down.
        Shafiq
