15 years ago2 kHz cut-off is fine, of course. The lowest cut-off, I could achieve with standard design methods was 45 Hz for a rectangular window and 75 Hz with a reasonable window function.
A 50 Hz notch filter, that can be also realized with 81 taps (although it actually uses 2 taps only) achieved about 25 Hz 3 dB cut-off for the first notch, but it's no low-pass.
