CJian2
8 years agoHow to configure the XCVR serial loopback for DP TX/RX IP core
After building the DP TX/RX IP core example design, how to configure the XCVR serial loopback to let the TX video loop to RX? Would someone please give some suggestion. thanks in advance!
Vicky1
8 years agoHi,
For serial loopback mode you need to use Native PHY IP Core, refer the Figure 32. Simulation Example Block Diagram for Arria V, Cyclone V, and Stratix V Devices from the following link,
https://www.intel.com/content/www/us/en/programmable/documentation/hco1410462777019.html
Check common interface: Control and Status ports under the Table 16-16: Native PHY Common Interfaces,
https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/xcvr_user_guide.pdf
Best Regards
Vikas Jathar
