15 years agoHow to change output format in Clocked Video Output
Hi, I have a question relating to the output stage of my VIP system. I have my video path working sending out 1080p @ 60 from a frame buffer without issues. My goal is to have the system ...
15 years ago --- Quote Start --- Is this true? That all video-related registers in CVO all are write-only? --- Quote End --- The VIP manual does state in a footnote to the CVO register table: --- Quote Start --- (1) The rows in the table are repeated in ascending order for each video mode. All of the ModeN registers are write only. --- Quote End --- I also noticed the manual states the following: --- Quote Start --- When the MegaCore function receives a new control packet on the Avalon-ST Video input, it searches the mode registers for a mode that is valid and has a field width and height that matches the width and height in the control packet. --- Quote End --- Perhaps the control packet actually has to change to be considered a new control packet? Although, it seems like there should be a way to easily force new mode settings even if the frame size has not changed.
