15 years agoHow to change output format in Clocked Video Output
Hi, I have a question relating to the output stage of my VIP system. I have my video path working sending out 1080p @ 60 from a frame buffer without issues. My goal is to have the system ...
15 years agoI haven't actually done what you are trying to do, but based on the documentation and other VIP experience, I have a couple ideas:
1. Are you clearing the GO bit, waiting for the STATUS bit to be cleared and then setting the GO bit again? (See the Avalon-MM Slave Interfaces section of the VIP document for some more details). 2. The CVO supports multiple banks of output configurations. If you have a 60Hz configuration before the 50 Hz one, you must disable the 60Hz configuration for it to use the later one.
