mnazemi
7 years agoHow to call an IP designed in Verilog in Intel HLS compiler?
Is it possible to design and optimize an IP in Verilog and create a function for it that can be called from HLS?
A simple example of such scenario would be as follows:
- Design and optimize an FIR filter in Verilog.
- Create a function for the design in HLS.
- Write a nested `for` loop in HLS that calls the function associated with the filter.
1 Reply
- MEIYAN_L_Intel
Since you created the design in HDL for a FIR, you can directly use it. You will eventually get HDL after HLS compilation.
