mifa
7 years agoHow to add Intel IP to Custom IP (hw.tcl)?
I am creating an IP with a bunch of Verilog files. In some of that verilog files I would like to use Intel IPs like ALT_IOBUF, ALTCLKCTRL or a FIFO. If I start the simulation with the generated simu...
mifa
7 years agoUnfortunately, that example you gave me only showed how to add some .v or .sv files.
I need a example for a structure like that:
- top_file.v
- file_a.v
- file_b.v
- ALTCLKCTRL (what I have to add?)
- file_c.v
- file_cc.v
- Altera DC_FIFO_IP (what I have to add?)
Adding the verilog files is clear, but what to do with the IPs? Is there a way to add .qsys or _hw.tcl?
Workaround ALTCLKCTRL: Fortunately, the synthesis creates the clock switch by itself. However for simulation, I had to make a extra simulation file, because it was not found there.
I think that way is still not best-practice.
