17 years ago
How efficient is DSP builder ?
Hi all,
In the year 2001 I witnessed the start of Xilinx Matlab blocksets, I tried them in my project, it was absolute failure so I abandoned them and went manual.
Later Altera produced their own(DSP builder) based on Matlab platform.
The idea of using any design acceleration is attractive to managers but has its own negative effects on designers.
I notice from this forum that many people are using DSP-builder. I would like to ask the actual design engineers(not the students) as how much weight they give to these tools. I know in some cases they give you a quick solution but they can't cover a wide range of cases e.g. you can design an FIR filter quickly(this easy anyway) but not FIR filters in multi-rate,multi-channel, TDM-based systems or even control its gain.
Away from any commercial bias, am I right?
Kaz
    I prefer to think about possible solutions before using the tool. It may be possible use simple concatenated filters based on shift and adds or subtracts to implement what you want, especially if you have some freedom of choice in what is acceptable ripple or cutoff.
    Nothing replaces a little bit of thought up front, but if the solution is not apparently simple by all means resort to the tool and save yourself a lot of time.
    Mind you, I still use assembler too; you can probably guess my age, its my birthday today.
