18 years agoHow do I tell Signal Tap to stop acquiring data?
Hello, I'm doing the "Getting Started" tutorial from the DSP documentation and so far that's done and it works great, but now I want to take the sine signal and display it when I press a button on the board using Signal Tap.
I know my issue has to do with my clock sample rate so I tried that, but now I believe my problem is how do I tell Signal Tap to stop acquiring the data? The test time I'm running under is from 0 to 0.000004, and the Clock sample rate is 25e-9, and Real-World Clock Period: 20. The Clocked_Derived time is 1/2, I have it there because I was playing around with the sample time to see different results. The trigger for the button signal is at rising edge, and the others are set to don't cares.No RepliesBe the first to reply
