14 years agoHow can I use clock signal
Hi, I am implementing Physical layer of a base band transmitter in simulink using DSP builder blocks. How can I use the clock signal in my design? I need it for implementing manchester enco...
14 years agoThanks for the reply but the problem remains;
All the registered DSP builder blocks uses an internal clock. I can just instantialte the clock block, I cannot connect it to any other blcok. On the basis of the registered dsp blocks (which uses the internal clock) I have developed my logic. Now I want to connect the same clock to a non registered blcok. Kindly let me know if any body know it. regards shah
