NN
8 years agoHi, While compiling a SOF with JTAG to Avalon master IP. Obtained Warning (12914): The file jtag_master16p0/jtag_master.sopcinfo, is not embedded into sof file as expected. Some tools, such as System Console, may not function fully. Any Solutions ?
And while trying to use the JTAG to Avalon master interface through System console it just hangs for one minute. Operations are not being completed. I tried searching for this issue in forums but di...
AnandRaj_S_Intel
8 years agoHi,
Can you help me to recreate the scenario with more information like.
- Quartus version and edition used?
- IP's used?
- Can you share the project file?
Can you delete the incremental_db and db folder or other quartus version and try?
Also try with example design from below link
https://fpgawiki.intel.com/wiki/Using_the_USB-Blaster_as_an_SOPC/Qsys_Avalon-MM_master_Tutorial
Anand Raj Shankar
