LLeta
7 years agoHi, it is not possible to connecte an onchip memoy (with ECC enabled) to the avalon data master or avalon instruction master bus of the NIOSII system through the avalon interconnect ?
Hi, I try to generate a NIOSII system with the following configuration using Quatus v17.1: NIOSII gen2 processour (reset vector and exception vector addresses are located in the onchip memory) On...
FawazJ_Altera
7 years agoHello,
On chip memory ECC is not supporting Nios II connection.
