14 years agohelp on Design guidelines for data transfer from DE2-115 to PC
Hello everyone, I am a beginner in the field of FPGA and I am currently working my way through a lot of information. As part of project, I need to transfer data from a FPGA board DE2-115 to ...
14 years agoHey Dave,
Thank you so much for your help! To answer some of your comments: 1) the bit are always produced. Treating as block would be possible, I think, but at this point this is just data bits. Ideally I would like the streamed bits to be routed directly to the Ethernet Link without using a RAM module (that I think require to assemble the bit into binary words compatible with the RAM modules). 2) I would like to send the bit at something like 100 Mbit/s (eventually more) or at the maximum speed (or close to) that the board can offer. What would you recommend to interface my verilog module with a Nios 2-based system? Thank you again for your help and your quick answer! Cheers.
