17 years agoHelp!! Error message
Hi, when i compile my simple design i get the error as such: Error reported by S-function 'sGeneric' in 'wateva2/Parallel Adder Subtractor': Loop detected while propagating bit widths for wa...
17 years agoTo set the bit widths, double-click on one of the blocks I mentioned. Then select the type parameter: this will currently be set to inferred and change it to something else like Signed Fractional. Then set the bit width left and right fields to some values.
If you still can't solve the problem, feel free to upload your design and we can take a look at it. Unfortunately a picture of the design leaves out a lot of information.
