19 years agohelp about FFT calculate
hello all: I am a new for FPGA. there has a problem that I want run FFT programme in nios .my nios type is cyclone EP1C6Q240C8, FFT programme is not a problem ,for there has many good progr...
19 years agoFirstly thank your help . yes ,it works well .but when the system make .sof file successfully . then the problem appear.:
Error: Can't configure device. Expected JTAG ID code 0x020840DD for device 1, but found JTAG ID code 0x020820DD. Error: Operation failed my nios ii development board version it cyclone EP1C6Q240C8, I want know whether it is not fit for doing this operation. thank you a lot . if not . then how I can solve this problem . Best wishes:)
