8 years agoHDMI IP core timing problems
Hello, I am trying to incorporate the HDMI 2.0 core onto an Arria 10 device (Quartus 17.0) and am having trouble with what I believe to be timing problems. The core worked great for TX, and wa...
8 years agoHi jdeffenb,
We are having somehow similar issues. Have you managed to resolved yours? In particular, have you had to add new timing constraints to the design? --- Quote Start --- Hello, I am trying to incorporate the HDMI 2.0 core onto an Arria 10 device (Quartus 17.0) and am having trouble with what I believe to be timing problems. The core worked great for TX, and was a little picky with RX on my original build. After incorporating the rest of the project which includes 8x GEN3 PCIe and a 10Gbps SFP+ transceiver, I am getting erratic behavior between builds. Sometimes no HDMI output, sometimes lower resolutions like 1080p will work but not 4k@30 and sometimes visa versa. When I say no output, I mean the monitor cannot detect a signal, I do see data going by with the scope. HDMI RX is also not working right, in that the core will not show vid locked. The only constraints I have in place for the HDMI portion are the ones automatically generated and the input clock of course. In addition to erratic behavior on the HDMI output, I also have trouble with my pixel clock randomly between builds. Pixel clock is generated from IO PLL and it sometimes outputs the wrong frequency (divide by 4 instead of 2 for example), and it will not recover between power cycles or recal. I am also experiencing long compile times ~50min not sure if that is normal or not for a project this size, or if that is evident of constraint problems? Any advice as to where I should be looking for problems? Thanks --- Quote End ---
