tm1701
2 years agoH-Tile PCIe Streaming Hard-IP - constrain application logic clocked by coreclkout_hip
Hello, we want to properly constrain our application logic of a design using the H-Tile Avalon Streaming PCIe Hard IP-Core. The Application Logic is driven by coreclkout_hip then later we have some...
Wincent_Altera
2 years agoHi,
I am the same Application Engineer who providing answer at the below forum (that you sent in this reply)
Yes, your understanding is correct for "coreclkout_hip is a 250MHz clock as stated in the User-Guide, and the clock shown by the timing analyzer is a clock internal of the PCIe HIP Core."
There is some confusing between the timing report comparing to the userguide, I will report to internal team again, hope they will fix this either in Quartus/user guide to avoid causing any confuse.
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
