K606
Contributor
1 year agoGTS PMA/FEC Direct Transceiver Streaming
I have been trying to set up the GTS PMA/FEC Direct on the Agilex 5 and would like to know how to stream parallel data to/from the GTS when the GTS does not expose a AV-Sink/Source on the parallel da...
CheepinC_altera
1 year agoHi,
Thanks for your update. Regarding the example design, just wonder if you could test with a simpler example design ie "1 x 1G PMA Direct Mode (System PLL Clocking) with Custom Cadence" to facilitate debugging. This design is running at lower data rate. You can first try running the simulation and then only on hardware.
Please let me know if you have any concern. Thank you.
K606
Contributor
1 year agoI just recompiled and tested this example, and found the same error!
