Jcole
2 years agoGeneric Serial Flash Interface reading only 0's
Hi, I'm using the Cyclone 10 EVAL kit with the EP128A flash connected. I perform the following events and made sure that the csr /mem wait requests were low before issuing the next command, but only ...
- 2 years ago
So it seems the issue has been with Signal tap all along, when I changed my trigger conditions to make sure pivotal actions were hit, then set my Storage enables to output when the rising edge of "avl_mem_readdatavalid", I was able to see valid and correct read data from the Flash.
FvM
2 years agoLooks better than your previous tries. Something is probably still missing . I'm not yet using General SFI IP, prefer simple and straightforward ASMI instead. I see that a lot of parameters has to be set.
Jcole
2 years agoThis one is supposed to use the active serial, is there something I need to set before hand that I possibly overlooked?
