Zak
5 years agoGeneric Serial Flash Interface (GSFI) automatic polling on write operation
Hello everyone,
I'm successfully using the Generic Serial Flash Interface (GSFI) to write/read from a MT25QL256 flash in Quad mode, 4-byte addressing (1-4-4 protocol).
The firmware bootcopier als...
YuanLi_S_Intel
5 years agoHi,
Can you try with 4 bytes programming? Since you are using 4 bytes addressing. Probably can try with 34H?
Thank You
Zak
5 years agoHi,
the write per se isn't the problem. The polling instruction 0x70 is.
With 0x34 and 0x38 I see no differences. I think that once the flash is set to 4-byte mode, you can use both with the same effect.
