18 years agoGeneral question about DDR2 megafunction IP
Hello, I am new to FPGA design and I need to use the DDR2 Megacore Controller. I read the user guide and other documentation i found but I don't understand everything... I have Altera PC...
18 years agoThank you franck for your quickly answer.
So, if I understand, I can address all my ram from "000..." to "111..." (23 bits) just like one component. Ok. Now, i understand. Data lines are 288 bits width and address lines are 23, so 8192 kWords x 288 bits equals 290 Mo. It's good. But what did you said: "I also calculated 23 address lines at the controller local bus respectively 25 at the RAM" Why 25 at the ram? Thanks for all! Fabrice.
